C4DES  |  General  |  Mundo 3D  |  Tema: Element 3D - After Effects plugin 0 Usuarios y 1 Visitante están viendo este tema. « anterior próximo »
Autor Tema: Element 3D - After Effects plugin  (Leído 3383 veces)
« en: 11, Julio ,2012, 04:47:21 pm »
Increíble plugin para After Effects.
https://www.videocopilot.net/products/element/
http://www.videocopilot.net/help/element/tutorial/basic/element_3d_introduction/
http://www.videocopilot.net/help/element/tutorial/basic/the_render_engine/
REAL 3D MODELS!
Import & animate 3d objects inside AE
3D FORMATS:
• OBJ files (from most popular 3D software)
C4D Files (without animation)
• No polygon limit!
WHAT ABOUT TEXTURES?
Element supports your UV texture coordinates so
it's easy to rebuild and import your textures!
3D OBJECTS AS PARTICLES!
ARRAY FEATURES:
Element uses a unique particle array system
that can distribute 3D objects into any shape!
3D SHAPES:
• Sphere, Ring, Plane, Box
• 3D Grid shape (XYZ)
• Position on OBJ vertex points
• AE Layer Alpha Channel
Element automatically identifies multiple parts of a single
3D object so you can animate with precise control.
POWERFUL MATERIAL CREATION!
CREATE AND SAVE PRESETS!
Import textures, edit options and save
custom presets for future projects
MATERIAL OPTIONS:
Diffuse
Specular
Reflection & Refraction (non-raytraced)
Normal Bump
Illumination
& More!
ADVANCED OPEN GL RENDERER
FEATURES:
• Use After Effects Lighting
• Environment Reflection (non-raytraced)
• 3D Motion Blur
• Depth of Field
• Matte Shading Material
• RT Ambient Occlusion (SSAO)
• Wireframe Rendering
• 3D Fog Falloff
INSTANT RENDER PASSES
Advanced compositing with multi.pass channels
Isolate specific attributes like ILLUMINATION
so you can add a target glow.
MULTI-PASS MIXER
Control the intensity of each attribute
while you work without slowing down.
Too much reflectivity? Just turn it down!
RENDER CHANNELS: Z-Pass, Wireframe, Illumination, Specular Normals, Reflection & more
AMAZING 3D TEXT
BEVEL FEATURES:
• Extrude Text & Mask Shapes
• Real Textures
• Built-in Bevel Presets
• Animate Individual Pieces
• Multiple Bevels per Object
ENVIRONMENT MAPS
Built-in reflection mapping
FEATURING:
• 10 Reflection maps
• Create Seamless Spherical BG
• Use for Reflection/Refraction
• Use Animated Reflection Maps
YuukiOuterelo
« Respuesta #1 en: 14, Agosto ,2012, 08:45:11 pm »
Doy fé, INCREÍBLE.  :o
Alguien lo probó para comprobar si realmente funciona? (Aunque VideoCopilot no suele decepcionar).
De pago también, imagino jaja  :'(
Focus Studio
« Respuesta #2 en: 14, Agosto ,2012, 10:03:49 pm »
Hola, yo ya tuve la oportunidad de probarlo y tengo que decirte que es de los desarrollos mas grandes que ha realizado videocopilot.
Se integra perfecto con cinema, puedes modelar en c4d y después en after puedes ajustar luces que inciden directamente en la geometría, y hasta texturizar es posible. Eso te ahorra tiempo y recursos.
Se trabaja muy fluido y sin contratiempos, trabaje en una mac pro con 2 core intel xeon y 16 de ram. Pense que esta maquina había sido la que me ayudo a trabajar bien, pero después lo probe en una core 2 quad con 4 gb de ram y tarjeta de video de 512 y a las mil maravillas no se quejo y el rendimiento fue bueno.
Lo recomiendo ampliamente.
Focus studio, sitio para todo geek audiovsual.
Tutoriales, video, animación, 3d, audio, web y más.
http://focustudio.jimdo.com/
C4DES  |  General  |  Mundo 3D  |  Tema: Element 3D - After Effects plugin « anterior próximo »
Página creada en 0.043 segundos con 22 queries.
