C4DES  |  CINEMA 4D  |  Plugins  |  Tema: QuadCaps plugin 0 Usuarios y 1 Visitante están viendo este tema. « anterior próximo »
Autor Tema: QuadCaps plugin  (Leído 420 veces)
masterzone
« en: 10, Enero ,2014, 03:49:27 pm »
QUADCAPS PLUGIN
QuadCaps is a Cinema 4D R13/14/15 plugin that helps user to close polygon hole with quadrangular mesh without creating Ngons.
The plugin's working principle is very simple:
1) Select the edge loop to close
2) Call QuadCaps tool.
The polygon will be closed with a quadrangular mesh.
If you want to change the start construction point just leave a selected point before using the QuadCaps tool, selected point will be used to start the creation of the cap.
You can close loop only with even number of edges and for the best performance of the tool close pseudo regular hole.
However if you need to close an uneven loop edge we have released another tool that reduces the number of edges but it will create a triangle.
The plugin works with all editions of Cinema 4D R13/14/15 (Prime, Broadcast, Visualize, Studio) and with all cinema 4D compatible engine renderers (V-Ray etc).
Cinema4D and system requirements:
-Cinema4D Version 13/14/15
-OSX Snow Leopard or greater
-Windows 7 32/64 bit or greater
QuadCaps is available at our plugin section store at price of 4,00 euro + VAT
http://www.c4dzone.com/en/blog/videoblog-1/quadcaps-plugin-311.htm
Thanks!
C4DES  |  CINEMA 4D  |  Plugins  |  Tema: QuadCaps plugin « anterior próximo »
Página creada en 0.033 segundos con 21 queries.
