C4DES  |  CINEMA 4D  |  Plugins  |  Tema: Arch-01 v4.00 0 Usuarios y 1 Visitante están viendo este tema. « anterior próximo »
Autor Tema: Arch-01 v4.00  (Leído 442 veces)
Caleidos4D
« en: 07, Diciembre ,2014, 02:07:29 pm »
Arch-01 is a modeling toolset that allows the user to draw geometry inside Cinema 4D with classic CAD like precision and workflow.
#FREE UPDATE FOR: Owners of older Arch-01 versions
Arch-01 v4.00: Overview Features Improvements
https://www.youtube.com/watch?v=Gi7fLwWPSHg
Arch-01 v4.00 contains Five tools:
1 - Draw Arc/Polyline
2 - Draw Circle/N-side
3 - Draw Rectangle
4 - Placer
5 - Object Dimension
Each Tool is controlled for common setting (snap, quantize angle ecc) by the Arch-01 Manager
With Arch-01 you can:
Draw Linear Spline as CAD
Draw Arc Spline as CAD
Draw Circular Spline as CAD
Draw Rectangle Spline as CAD
Get Distance between 2 points in real Time
Get Length Spline in Real Time
Get Area from Selection Polygons
in Real Time
Get Angle between 2 points
Place objects or copying of objects
on polygons surface or polygon points
Choose a Layer for each object create
Choose a Color for each object create
Isolate the selection Objects
Make a Polygon from Spline
Cut a Polygon from Spline
Get Intersection Point from
2 Polygon Edge
Add Objects for quote distance
Cut selection Polygons
Copy selection Polygons
Paste selection Polygons
Clone selection Polygons
INFO: http://www.caleidos4d.it/plugin_arch-01.htm
Changelog: http://www.caleidos4d.it/index_htm_files/Arch-01_Changelog.txt
User Manual: http://www.caleidos4d.it/index_htm_files/Arch-01_v4.pdf
C4DES  |  CINEMA 4D  |  Plugins  |  Tema: Arch-01 v4.00 « anterior próximo »
Página creada en 0.038 segundos con 23 queries.
